Hello,
I bought a seadoo gtx 2004 with some driveshaft issues. The thing is that it is slipping at high speeds/rpm. The shaft teeths on the impeller side has worn a lot and need replacing. The one thing I do not understand though is that it seems like the shaft is not reaching far enough into the impeller, so the teeths are not fully in use.
Anyone know what the issue can be?
PS: Just answer if you did not understand and I will try to explain better.
- Thanks
- Thanks
