Di Odd colored fluid on the top of the piston
Boyd12
I have a 951 Di and below is a poor image of what appears to be greenish fluid on the top of the pistons (both equally). I have NO idea what it could be. Any ideas?
THANKS!
Moisture on oil which is common on the 951 and why it should be fogged after every use.
The fluid looks to be green/brown; I don't know how this could occur, but could it be balance shaft oil getting into the combustion chamber? The engine passed the leak-down test.
Does adding moisture to red SD synthetic oil cause it to change colors?
Could it be fuel related?
My concern is that I do not smoke an engine due to something fixable!
It’s oil and fuel and water. All the 951’s do it because somehow they get moisture probably from the exhaust.
This why you have to fog.
