De-Winterizing
kcrollins1
I have a 95 Speedster that I recently bought. The guy that I bought it from did hook up a water hose to each motor and start each one.
My question is, is there anything else the I should do to get the boat ready for the water?
change plugs, service oil system, check: fuel lines, fire extuigisher, fuel fillter, oil fillter, hull for cracks. if you raves, clean them. if you have grey fuel lines replace them. if your oil lines are more than two years old replace them.
Since the boat is new to you... you need to do more than just De-winterize. You should check the oil in the jet pumps, check the oil injection, and service it. Also... if you don't know exactly what oil is in the tank... I would drain it, and refill with a good API-TC oil.
