I've got a 95 GSX that isn't starting.  I've got power in both the rear electrical box and the front box at the MPEM.  My dess post doesn't beep and the guages won't come on.
I'm trying to check my grounds (among other things).
1. I've read where there are normally 6 different grounds. Can anyone tell me where all of those are located?
2. I've jumped the starter relay and it turns over. I've tested it - the battery side of the post shows 12 volts. The wire running to the starter doesn't show any. What does this tell me?
3. I pulled the harness in the front of the engine (I think this is the Magneto Harness). Is there any way to test this plug (in the shop manual on page 8-02-11 it shows a harness adapter {P / N 295 000 131} which I don't have to test the resistance)?
Thanks
Thanks
