award64
Couple of quick questions after a long description. I recently bought a 2000 RX and a 2000 GTX RFI. The GTX did not run and after looking into it, found that it had completely shredded one of the pistons, (See pics) so I decided to replace it with a SBT rebuild. After finally getting that installed and running (after replacing the fuel pump as well) I started looking at the RX which does run but needed a few minor fixes. i.e. replacing the spark plugs. On doing this, I noticed the fuel gauge did not work. I have since found that the float was full of fuel and have ordered a replacement as well as the 1A fuse is blown so I will be repairing that as well. While researching the fuel gauge problems I found that the grey tempo fuel lines need to be replaced as well, so now I am working on this... And on and on and on.... :facepalm:
Now for the questions...
1) Does anyone know how many feet of 1/4 and 5/16 line I need to buy for the RX, and do I need to use marine grade line or will regular line from the auto parts store work?
2) Other than the main fuel filter, the carb filters, and the fuel switch, is there anything else I need to look at or clean when I replace the lines?
3) Do I need to replace the lines on the GTX? Since it is fuel injected, I assume it is using a different type of line even though it is still Tempo. I cannot find anything on this and would like to confirm.
4) Does anyone know what could have caused the damage to the piston on the GTX? Just want to do what I can to prevent it from happening again.
Please feel free to comment on anything you think may help. I have owned several boats, but these are my first ski's and I am still low on the learning curve.
Thanks in advance for any input you may have. As I said, these are my first ski's and after all the money I keep sinking into them it would be nice to get to ride them at least once. :drool5:
