I am just wanting to know whether the Cooling system indicator (CSI) has to have water coming out of it when on the water or just when it has the hose attached being flushed?
Thanks
alot of times there will be no water or very little water coming out when on the hose, this is ok
as long as there is water coming out when ski is in the water you should be good
mud
Hi
this is the problem the water comes out when the hose is on but does not when it is in the water. this seems odd, as i thought it would have to come out in the water and on the hose.
Please help?
thanks
Are you saying that it does not come out of the [pisser] tale tale hole when in the water but it does on the hose? If so I would think that you have a restriction some where. If so it may only be affecting the pisser but you need to fix it either way. :cheers:
this is odd?
normaly its the other way around!
have you driven this boat yet? does it drive proper?
will you get any water out pisser when in water? at idle or when you rev it up?
need to know
mud
