pipedragon
Just had this one come up on my 08 RXP-X. Everything about the ski works fine otherwise. Battery was good and charged but I would put key in try to start and just hear a click sound, one more try and click, then third or fourth time it started. Kinda scary if your in the middle of the lake. Turned out to be a bad solenoid or what Seadoo calls a starter relay. I ordered a new one for about $45 from http://www.XXXXXon.com the swap out took literally 10 min. just be careful not to drop the nuts into the hull or they are gone. I suggest a towel or blanket underneath to catch, just be sure to remove it after your done. Also obviously disconnect the battery first. It's good as new now and starts first try every time. Hope this helps someone else from a bad day on the water.
