Circuit breakers vs. Fuses
Schnitt
Hello all some may think this might be dumb question but never hurts to ask. Can a circuit breaker be installed in place of a fuse. Example the 30 amp fuse holder on my 2003 gtx 4tec sc ltd is deteriorated so bad that I will blow a fuse more and more often. Would like to replace with a 30 amp circuit breaker but a little concerned if it could do any damage. Anyone with knowledge please tell me your thoughts
If the connection at the fuse is causing it to blow then putting a breaker will probably cause the connection or what ever is the cause to melt , the breaker will continue to heat and cool until there is a failure or the power is disconnected. I would replace the fuse box if the connection is the real problem.
