chock wont push shut
Choke lever won't go back? If it's just the lever and the carb choke is ok then you probably have some broken or frayed wires on your choke cable. mine was stuck and when I pushed / pulled on it, it broke. I replaced with a used one off of ebay. Simple fix.
To check to see if its the cable or the bushings on the choke valve,(butterfly) loosen the cable adjustment from the carb linkage, and see it you can open and close it by hand. It should snap open after you close it, with the cable removed. That will tell you if the cable needs lube or replacement.
Karl
my boy fixed
My son came over and was able to get it back inno problem, now goes in and out smooth ,go figure, thanks guys goin out tomorrow, yee ha:hurray::hurray::hurray:
