Getting ready for first winterization.
Manual says check engine drain hose running from engine manifold fitting to outlet socket. Make sure there is no sand etc. in it....
How do you check this to get ready for winterization? The whole thing to me seems sealed up as most of it is metal tubes. Not sure how I can see/know if there are any obstructions in it. I am wondering though if I am talking the correct piece? I am referencing a tube connected to the purple cylynder at the rear of the boat that exausts water (the exhaust pipe). Is the manual referencing me to check the smaller blackish (it might be clear I cannot remember right now) flexible tube (about 1/2" wide) that runs from the engine, has a "t" in it of which one goes to the drain outlet (where skis are hooked up) and the other connects right near the exhaust outlet? If so again, how is this checked for obstructions.
thanks!
thanks!
