68ragtop
I thought that too [MENTION=53237]mikidymac[/MENTION]. I had the nipple in, and tight, and it did drip, when hung. I know with the exhaust pulled, it would not be hard to do on the 03 and 02 gtx, but they were designed for a 4 stroke, so I have lots of room LOL.
Both engines I got had very little oil in them. The first had the gears torn up, and was rebuilt before, so it was possible that they did not refill the cavity.
The other engine was an 02 DI that lost its bearings and crank.
Thats what I think kills half of the DI's. No fuel through the case, just oil, air, & tons of moisture. Seems the bearing rust easier in DI's & eventually come apart. Especailly if they sit for lengths of time. I think removing the seat, letting them cool off & re-starting them for 20 seconds could make a big difference in bearing life. Fogging them after use, No doubt would.
What I find interesting with the DI's is after you let them cool off to room temperature you can pull the spark plugs & they will usually have a drop of condensation hanging off the electrode, I have never seen that on any other engine. could be the position of the plug & the angle of the cylinder. Not sure. They will also get some light rust on the cylinder walls if a cylinder is at BDC when it stops.
