Check Engine Light
lubepimp
After launching the other day, then letting my 2020 Wake 170 sit for a bit, I started it up and the CEL was on. Iet it idle for a few minutes, it didn't turn off, then when I hit the gas it turned off. She ran fine. Didn't see any codes or error messages and can't figure out how to display any saved codes on the display. Before I take it to the dealer was wondering if any impedements (weeds/gravel)in the impeller may have caused the light to go on, then they got blown out and all was good? Would that cause the CEL to come on without codes? TIA
if you have active codes, they can be accessed through the display after you wake up the ski by pressing the mode button until you come to the selection called Fault Codes. You can use the up down arrows to go through the codes if there are multiple ones.
