BZZZZT wrong answer :lols:
put the pumps back on. ok to just hand tighten the nuts.
now climb in the boat.
remove the shield that protects the carbon seal/PTO at the back of the engine.
while the pumps are in place, push the floating ring against the carbon seal forcing the accordian boot to squish and move towards the rear of the boat.
move the floating ring rearward enough to expose the "C" clip
while holding the floating ring in that position with one hand, remove the "C: clip with a cotter key puller, or pick, or small screw driver. I suggest placing a towel or shop rag under the drive shaft to catch the "C" clip and any parts that drop when removing the drive shaft.
after the "C" clip is removed, unlock the SMALL oetiker clamp on the small end of the PTO BOOT... this rubber boot is at the PTO and on the drive shaft.
after unlocking the clamp, go ahead and remove the jet pump.
now reach in the tunnel and grab the driveshaft and slowly/steadily pull the shaft out of the boat. you will here the floating ring drop, and maybe the oetiker clamp fall from the boot... reach in the boat and grab them before they get lost.
NOTE how the orientation is of the oetiker clamp...
I suggest downloading a shop service manual for the correct torque specs and illustrations of the O rings, what needs to be greased, what DOES NOT get grease, etc etc...
good luck...:cheers:
see picture for PTO boot, oetiker clamps (large and small), floating ring, carbon seal and bellows (accordian boot)
