Changing to premix on my 97 gsx 787
JETSKILEE
I have the block off plate what do you do with the cable going to the pump from the carbs and what do you use to plug the hole in the oil tank that the small line comes off of?
if you got the kit, then you should've got 1 big cap and 2 small ones, for the brass fittings, on the manifold.
The oil cable, is removed.
