Changing a flat tire? Tandem axle
briancayko
Has anyone used on of these for changing flats?
Trailer-Aid Tandem Tire Changing Ramp, The Fast and Easy Way To Change A Trailer's Flat Tire, Holds up to 15,000 Pounds, 4.5 Inch Lift (Black) https://www.amazon.com/dp/B000YOH16I/ref=cm_sw_r_cp_api_lf1FAb0JA5YWC
A lot of review I saw said it won’t work with certain trailer suspension. My 2010 C210 se is tandem axle & leaf spring suspension & not sure if it will flex too much as to not lift the other tire off the ground enough to change it?
I use this. You put it up against the axle shaft and either pull ahead or back up as needed. Takes up very little room and works well..
For some reason, can’t post the picture right now, here is a link,,,
Redirect Notice
I've always used a bottle jack. Cheap and small. Easy to store. I also keep a small cutting board under the seat to give the jack something to sit on if I'm ever in sand or soft dirt.
