cavitation?
srilla
my jet ski almost feels like it it cavitated like it would feel if i pulled up some rocks. but i know for a fact i did not pull in any rocks. it like studders and now it work go top speed? i just put in a new starter, but previous to that i was waterskiing on it as i was told it has 110 horse power and it would do it easy and it seemed like it had trouble pulling me. i do believe that is what caused it.
any replys would be extremely appreciative
Look under the hull; maybe you sucked up some grass, weeds, a rope, or something and it is wrapped around your drive shaft.
It could be the wear ring is damaged or worn out, and in need of replacement. Wear Ring clearance for your seadoo 1.0 mm or (.040in) Measure the clearance at the center of the impeller blades, with a 12” long gauge. Measure the clearance from the venturi side of the jet pump.
Karl
my pto boot was shreddded when i was water skiing, i was told thats what the problem is. is that right? the wear ring looks ok. i had this wear ring for almost 2 monthes so its preaty much new
i too believe that waterskiing on it caused it to studder on the work go top speed.
