Carburetor ultra sonic cleaner suggestion
dontilgon
Premium Member
Premium Member
Just purchased one and know nothing about them. I read to can burn the aluminum using the wrong cleaner or amount. So my question what should i use. What you see in the pic is 48 hours in carb cleaner , pressure washed and compressor air dried.
If you can find it, the Simple Green Extreme aircraft cleaner is aluminum safe. Otherwise, I’d check with a local food and beverage equipment supplier and see what they have that is aluminum safe... It’s a common thing in that industry.
Well, are the important parts clean.....the insides? The stuff on the outside is aluminum oxidation. Harbor freight sells a small stainless steel wire wheel/brush kit to use in a drill. I would use that to clean the outsides and knock the ugly off them.
