Carburetor Problems
H2_Mx5
So I took the ski out today and it stars up fine idles fine runs until you give it full throttle then let out. Once you try to give it more throttle it Boggs down then dies. After you start it again it has issues re throttling. Like it doesn’t want to run . Any help?
Sounds fuel delivery related,,,run the in line from your pickup directly into the carbs to rule out issues up stream to start,,,assuming also you don't have the gray fuel lines.
I Don’t have the grey lines there black
