carb screws
anyone know the size of these screws that bolt down the pump body assembly
http://www.watercraftsuperstore.net/Mikuni-Carb-Screw-1-2.html
they are out
Little hard to tell from the picture ... which carb and where do the screws go exactly? The only flathead screws like the one pictured that I'm aware of on my SBN38i Mikunis hold down the check valve body internally and the diaphragm cover. The pump body (fuel pump body) are held on with M5 roundhead JIS screws.
The internal screws I believe are:
Check valve body screws flathead JIS m4 - 0.7 x 14mm
N/S retaining screw round head JIS w/washer M2.5 - 0.45 x 8mm
Needle arm pin screw oval head JIS m2.5 - 0.45 x 8mm
Check valve retaining screw button head m1.6 - 0.35 x 6mm integral washer head
You can get a full set of internal or external screws from OSD in stock. $3 ext $6 int
Or by the drink from Fastenal
do you happen to know what the external carb screw sizes are
thanks for all the help
