I have a 1990 sp with the yellow 580 motor that has a round body mikuni 44BN on it. The previous owner said it had an aftermarket/modified rotary valve which warranted the larger carb.
However I am having a hard time tuning it after a carb rebuild and would prefer to start fresh with a new one. (it never ran right since I bought it- definitely fueling issue)
From what I have read the SBN is a much better and easier to tune carb than the BN. Should I keep the same size 44mm carb or would I be safe going down to a 40mm? I think stock was 38mm without the modifications.
It also has the external pulse operated fuel pump if that makes a difference.
