dabernathy8181
2000 seadoo GTI, just rebuilt the carb because the motor was getting a little boggy on restarts. I believe I know what the culprit is but I wanna see if others have the same opinion. So the ski cranks a little slow when it's cold, but will idle perfect once it cranks. Once the initial crank happens it cranks perfect as well. I've done the carb adjustments and the mocha brown color is what I have finally landed on. Now here is the head stomper. If I give it full throttle it jumps out of the hole like a rocket ship and runs perfect. But if I barely give it any gas it bogs down and dies out. I thought that there was possibly an airleak near the carb mount causing this after reading a thread on here so I pulled the carb and replaced the gasket. The pto cylinder was overly oily/black but the mag cylinder was showing perfect on the plug. Now I am leaning towards an issue with the internal fuel pump not being able to generate enough pressure at low speed but it overcomes it at high speed acceleration. I used all Mikuni rebuild parts, went down that road before with aftermarket vortex kits and chased an issue for the better part of 2 months, plastic parts were to thick. So am I off my rocker in thinking the fuel pump? I installed the diaphragm correctly but may have deformed it when installing the little black rubber piece cause they are a doozy. I have not checked compression recently, ski only has 150ish hours on it but leaning away from that.
