carb help
dannyd310
hello
i have a 2001 seedoo 3 seater gti
i have a black carb on it i need to buy a new 1 does anyone know where i might buy a new 1 at a decent price and and canany one tell me the part
number i tryed to rebuild it but it still stumbles
and question 2
why do i have prime with prime button every time i start
getting to be pain in the rear
thanks
dannyd
Buying a whole new carb can be expensive. Make sure that when you rebuild it you check the pop off pressure and do a needle and seat leak test. Also, you might have to adjust the Low Speed and reset the idle on it after a rebuild.
Pop off should be 36psi min 40psi max
Low speed setting 1 turn ± 1/4
High speed at 0
Idle speed (in water) 1500 ± 100 RPM
Idle speed (out of water) 3000 RPM
