Can you flush the engine w/ the boat in water?
randy_oneal1
I am thinking about renting a slip at a marina for the month of July and I was wondering if I can flush the motor while the boat is still in the water or would this be pointless? Would it force too much water into the engine?
If this won't work will it hurt if I just pull it out and flush it every couple days?
Any ideas about this?
Seadoo recommends that you don't leave your seadoo in the water for any extended period of time. There is no way to Flush it in the water as it has to be running to flush it. If it's running it will force water into the cooling system from the impeller, so it will be pointless.
You need to add your seadoo model and year to your avatar to help with future questions on your seadoo. Use mine as an example.
Karl
Thanks, that's kind of what I was thinking! Maybe I can find a slip with a lift on it.
I thought I had my boat model on there, I'm glad you caught that!
