Bought a GTS 1994 and no spark
gtr86
Have a 94 GTS and ran ok for a day or so after we pulled it from past owners and they stated it had issues too of running bad... then started to fall on it face a little the first day out, then got worse as you rode it, stick the throttle and it would almost die then run full out then would hardly idle, will struggle to go in N & reverse wanting to die, now it wont run at all... then hit starter and it may fire up but not run right" doggy" and loading up smells like fuel, compression is 145 in both, pulled carb, looks great, cleaned internal filter, tried checking for spark and cannot see it right now.........Any ideas on may being spark? How hard is it to get brain box out or even open to see coil if that could be it.......help....?
