M mchinn46 New Member Sep 16, 2022 #1 I’m looking for bolt size for motor mounts and the bolts that go into hull for motor mounts 1997 sea doo xp 787
etemplet Moderator Moderator Sep 16, 2022 #2 Do you own due diligence but this is what I found. The link is below. Good Luck. M8 X 70mm (2) rear mounts - need 4 M8 X 16mm (2) rear mounts - need 2 M8 X 20mm - Front mount - need 1 M8 X 40mm - Front mount - need 2 Find them here. Seadoo Parts
M mchinn46 New Member Sep 16, 2022 #3 etemplet said: Do you own due diligence but this is what I found. The link is below. Good Luck. M8 X 70mm (2) rear mounts - need 4 M8 X 16mm (2) rear mounts - need 2 M8 X 20mm - Front mount - need 1 M8 X 40mm - Front mount - need 2 Find them here. Seadoo Parts Click to expand... Are these 1.25 or 1.50
