doberdann1019
I have had trouble getting my 97 XP to start. Last night I started troubleshooting, looking in the MPEM fuse box I found a blown 15A fuse where the 7.5A VTS fuse should be. At the time I did not realize that it was supposed to be a 7.5A and replaced it with another 15A (which will explain the second part of this posts title).
I also looked in the rear electrical box and found the 15A fuse blown and about 1/4" of water in the bottom of the box. I got the water out and replaced the fuse.
I then tried to start it, plugged in the key and the vts needle bounced (this usually happens, I have never gotten beeps). Nothing happened when I pushed the start button, I hooked up my charger and it showed 50% so I left it on the charger.
Came back about an hour later to check it and I smelled smoke, took the charger off and started to look for the issue. the 15A fuse in the rear electrical box had blown again. I could not figure out where the smoke had come from so I replaced the fuse to see if it would happen again (charger still disconnected).
Pretty soon I heard sizzling and (because it was getting dark) I saw a orange glow coming from behind the VTS module and quickly unplugged the rear electrical box.
The VTS worked when I got the ski, not sure when it stopped working but when I had it in the water last month it was no good.
I took some pictures and realized the MPEM shows which fuses should be where, I had both the VTS and battery fuse over sized, thank you previous owner...
I ripped the exhaust hose out of the way to find a hole in the back of the VTS box.
A small amount of water did come out of the VTS box when I look the cover off.
