Bimini Top Repair
cnhaigh
hello, have a challenger 2000 with a factory Bimini top. One of the internal style ends has come out of the centeral support rod. I have tried just about every way to get it to go back in. It just wont do it. Will I have to replace the entire frame assembly? Yes i have a 240EFI boat, but this forum is way more active.
Thanks,
C
You can buy the ends for a few bucks. You can drill a dole and use a screw to hold it in. I have a few spares from the bimini i destroyed last year. I will see if i can dig em out and take a pic.
Thanks, obviously the compression ridge is cut in after the end is installed. Weird is that some are the set screw type, and some that are the compression type.
