rgardner928
So I got my bimini on and I don't have any issues with it. I do not leave it mounted up or open while traveling on the highway. I leave it laying flat against the hull. And to prevent it from bouncing around I bungee cord it down. Put the metal of the bimini itself is rubbing very badly against my finish. If you look at the following pictures all the black marks are from it rubbing. When I lay it flat down the way it sits it rubs badly. It's also damaged some of my finish. Do they make any cover or protective pad I can put in those spots that will prevent it from getting any worse? Do you know of anything I can use if they don't make anything, to help prevent if from happening.
Does anyone else have this issue?
No maybe its the wrong one/size. But its what the pervious owner had installed. All I did was swap out the plastic hardware for stainless. I really don't want to buy a "new" one..I'd rather spend to prevent it from happening more.
