M MTHancock New Member Feb 16, 2020 #1 I’ve tried a few cheap oil extractors and am ready to give up and pay what I need to pay. Any suggestions on which one to get?
JPass Well-Known Member Feb 16, 2020 #2 I've been using this PELA Extractor for the past 7 years with no issues. Used it today as a matter of fact to do the annual oil change.
DooGuy Active Member Feb 17, 2020 #3 JPass said: I've been using this PELA Extractor for the past 7 years with no issues. Used it today as a matter of fact to do the annual oil change. Click to expand... What oil do you use?
briancayko Active Member Feb 17, 2020 #4 I have essentially the same one. It is slow but gets the job done consistently.
JPass Well-Known Member Feb 18, 2020 #5 DooGuy said: What oil do you use? Click to expand... I use the XPS OEM oil. Just changed it the other day, I believe it was 5w40.
briancayko Active Member Feb 20, 2020 #6 Here is the kit I get each fall. it’s 5w 40. Sea Doo 4 Tec Oil Change Kit w/ Filter O Rings & Spark Plugs 2 Pack GTI GTX GTS Amazon.com: Sea Doo 4 Tec Oil Change Kit w/ Filter O Rings & Spark Plugs 2 Pack GTI GTX GTS: Automotive
M MyFirstSpeedster Member Mar 31, 2020 #7 I have the Mity Vac MV7400 Fluid Extractor. It works well; about $80 on ebay.
skiasylum Well-Known Member Apr 1, 2020 #8 None of them work good if the oil isn’t warm, just in case.
