Beating a dead horse.... Flush kit for 05 Challenger SCIC and fogging oil??
SLOWBRAH
I know... I'm sorry to beat a dead horse... but..
1.)I've seen a ton of flush kits... what works best for my 05' Challenger? To flush with fresh water and to add the antifreeze.
2.) What oil is suggested for fogging the cylinders? Just pull the fuel rail and injectors and spray while turning over, correct?
3.) Cheapest place to pick up a manual?
Thanks Gents...
Manual- free online
Flush with hose on back pump - That's how my speedster is anyways
Fill a bucket with antifreeze and use a bilge pump with a attachment and hook it up to the flush port as well. Now run the boat and start the pump. Stop it when it starts coming out and then shut the engine off. If its not supercharged just blow air thru the line to clear out any water in the manifold. Then detach rubber hose on waterbox and pour antifreeze in there. There are many different ways and thoughts on this.
Fog with sea doo or any other brand fogging oil, pull fuel rail and fog in each hole, turn the motor over in drown mode and fog a little more.
Check your PM ;)
