seadooNY575
I have a 96 sportster and in the past have had some problems with the battery keeping charge while left on the boat. My repair guy said that it was because I left the battery connected while not in use and that the electrical system would place a load on the battery even while not running. Recently I bought a battery tender and began to remove the battery while not in use to keep it charged. The last time I went to connect it, the boat would not start and after much frustration I realized that there are two negative terminals (one to the ecm/mpem) and one that goes to the engine. I discovered that if I connect the terminal from the ecm/mpem it will start, if I connect only connect the terminal that is connected to the engine it wont start and if I connect both it will start. It is my first boat and I dont ever recall both terminals being connected at once. Im assuming both need to be connected to complete the circuit to the electrical system but I am wondering if this may be the cause of my previous starting issues. Any help/advice is appreciated.
