Battery getting hot and staying hot even after sitting
Brprxt215
Fell off the ski yesterday and it would double beep and crank after for about 3 mins then no beeps and no cranks. Pulled agm battery out and it was pretty warm to the touch. Put in a acid battery I know wouldn’t fire the machine but at least crank with plugs out and grounded. So I turned it over a couple times with plugs out and walked away for a couple hours. Came back and the acid battery was also warm to the touch. I put in a brand new non Chinese rectifier recently and have to test it later today. Does anyone have any input as to what I should check? Ohm test the stator?(what would correct ohm be) dc volt check the rectifier? Dc volt check the rectifier when revving? Dc volt check the battery? Check fuses in ignition box and vts system?
