Canty
I'm still trying to exercise the demons out of my 03 GTI LE. Today was the 1st time on water since 2015. On the trailer it seemed fine. I did put an RPM reading timing light on before I left to set idle at 3k. The readings were all over the place. 3700, 5400, 9999. The ski idles smoothly so not sure about the sparatic readings. Oh well, off to the water. Hard to start even with choke. Once it ran a while then it was quick starting. Okay so in the water it idled fine. Slight throttle was fine. Mid range throttle it would die out. If I went past mid throttle to WOT it ran fine. When I let off WOT it would back fire through carb. So bad in fact that it blew the cone shaped exhaust off the round exhaust. Sorry I dont know the names of the pipes. When it blew the pipe apart it was a loud pop then the motor struggled to stay alive. It sounded terrible then died and would not restart. I only tried for a few seconds though since I did not know what had just happened. When I got home it fired up right away. I reassembled the pipe, started it and it revs fine. But when I let off the throttle at high revs it still backfires through the carb. Any ideas? When I had the motor out on the work bench this past winter I did verify timing with a guage. I have had a TON of issues with this carb. Time to get a new one?
