roneagan@cfl.rr.com
This is more of an FYI on the automatic bilge pump in the 98 Sportster, I am sure others have the same setup.. My automatic sensor would not turn the pump on when the bilge filled with water.. I read someplace else that the automatic sensors can get corrosion on them causing them not to work.. So
I took some break cleaner and a rag and cleaned the sensor, then for good measure opened up the plug in the sensor circut and put some dielectric grease into the plug.. The good news is it know works great, I almost bought a new sensor but figured a little time was worth the effort.. Another little problem solved....
