So after 3 years of no boating after having children, I'm getting the boat back in shape. Engine has been rebuilt (low compression on one, and oil seepage on both made us mosquito sprayers quite a few times)
I have been unable to get parts to rebuild the OEM fuel pump, but I do have the Mikuni Built-in Fuel Pump that goes attached to the back of the carb in Jet Skis that share our carb and engine.
I'm unsure it will work. as I suspect there had to be a reason for the original designers of the boat to use the external fuel pump (Which is more complex and expensive install, requires several additional parts to the boat...it would have been cheaper to use the built in one, so I suspect if they did not use it, it's because it didn't work)
I'm hoping someone tells me I'm wrong and that you know this set up to work because you know of it working, or saw somebody's work. I'll take your thoughts too if you fell like sharing!
Thanks !!
Thanks !!
