Coopnjaxdad
Well, my 1997 XP gave all the typical starting problems and went through all the normal steps to remedy. Ski has new AGM battery, new starter, new ground cable, cleaned ground connection in coil box but still no consistent starting.
Here is where it gets interesting. With plugs out ski turns over fine. Nothing strange there. When I lift towel cover head there is a ton of oil coming out of PTO cylinder. If I get most of the oil blown out and put plugs back in, the ski will turn over like normal for two to three 5 second starter runs. Then goes back to just clunking. If I pull plugs she turns over and blows a whole bunch more oil out of the PTO cylinder. I can repeat this scenario at will.
So my question is what's with all the oil in the PTO cylinder and do you all think that it's causing the no spin condition or is it just an unfortunate coincidence?
Thanks in advance for the thoughts!
