annoying 3 beeps on speedster v6
blueodile
hi have just bought 2003 speedster 240 v6 and drives spot on but yesterday it beeping 3 times every couple of minuets whats wrong boat runs fine no loss of power water coming out the side as usual
According to the manual three beeps means that the engine mounted oil reservoir is low. Check the oil level in both your oil tanks before you run the boat again!!
If the boat is new to you, change the fuel/water separator, as if the sensor in it detects water it will also cause a series of beeps.
Aaron
beeps
both 2 stroke oil tanks are full only bought boat a couple of days ago and it ran fine first day now beeps second where is the seperater and can it be cleaned
Make sure the float is not sticking in the oil tank. The fuel/water separator is not cleanable it is a spin on filter that should be replace once a season. Part number 35-18458T4.
Aaron:cheers:
