Hi Seadoo gang.
After three months of very intensive rebuilding of my '99 Challenger, I am almost there.
What seems to be the last issue with the engines in this otherwise nice boat is that when I get to about 5500 RPM on the right engine it bogs down to about 5100-5200 RPM and stays there even at full throttle. The right engine goes up to 7000+ RPM with no problem. I did notice a little bit of surging on the left engine (about 100 rpm up and down but hard to tell). Sometimes, as the boat picks up speed, the left engine RPM will slowly go up and then at times hit the higher rpms (I think about 6000-6500 rpm but could be more). But this increase is slow and only as the boat picks up speed.
As the left engine sits at the low rpms, it seems to run smooth except for the very slight surge. Another thing, when running in this state I tried pulling the choke and no rpm increase, it just bogs down further.
Things I have taken care of:
- New rave valves, housing and bellows.
- Rebuilt carbs and actually pulled them out again last week and rechecked all including pop-off. Changed main jets on both carbs to those specified in manual (145 and 142.5 I think).
- New plugs
- Swaped water regulators
- Compression on both cylinders (150)
- All new fuel lines, impulse lines to fuel pumps and fuel filters
- Rebuilt jet pumps (all bearings and seals)
- Impellers are Solas SF-CD-15/23 ), Solas recommends SD-CD-15/23 but I don't know if this is an issue).
Things I haven't done:
- Swap fuel pumps
- Check ignition timing
- Check rotary valve
- Check for seal leaks
- Is there quick way to verify enough pulsing to fuel pump?
I recently bought this boat so I have no idea what previous owner may have done to it that I don't know about.
Since the engine runs so strong and smooth up to 5500 RPM, even with throttle at full, I just don't know what else to try. My next attempt at fixing this will be swapped fuel pumps.
Any ideas?
Chris
- New plugs
- Swap fuel pumps
Any ideas?
Chris
