Aftermarket Steeringwheel Fitting???
Prolly need to make a custom one any machine shop could whip one up in no time out of aluminum..get it powder coated white to match...
Is it one of those gold chain pimpin wheels..? :rofl:
i dont know if you have a fix for this yet , but here you go ,
Grant steering wheels are universal and they have several adapaters.
You pick the wheel of choice and find your adapter.
If you are near an autozone, advance, oreilley sometimes they stock.
on the application chart hit year then marine etc.
good luck.
Grant
Marine Installation Kits
The die-cast aluminum 5-bolt pattern style hubs feature a textured powder coat finish, include 5 stainless steel bolts and a plastic center cap.
Model # Application Hub Type
3650-1 Marine Hub to fit 3/4" tapered shaft with keyway. 1-3/4" high. 1
3655-1 Tall Marine Hub to fit 3/4" tapered shaft with keyway. 2-3/4" high. 2
3656-1 Splined Marine Hub to fit standard splined shaft. 2-3/4" high. 3
http://www.grantproducts.com/c-198-how-to-buy.aspx
The adaptor is a regular ¾ tapered (and keyed) hub. (as listed above) You can get them on eBay for around $35.
Or… like Cid6.7 said… get a shop to make you one. (here’s the one I made) Don’t worry about powder coating it… billet rocks!!!
Adaptors
I have enclosed a link to Juliano's.com hot rod parts. They do a lot in steering wheels. There is also Lokar.com I will paste in some adaptors. I don't know the pattern for the Sportster.
Mike
STEERING WHEEL ADAPTER
6 Bolt Gm Style Adapter
6 Bolt GM 67-94 Tilt & Telescopic
9 Bolt GM 67-94 Tilt & Telescopic
9 Bolt GM Style Adapter
