admitting defeat
emtmike
I have tried everything I know how to do. I have replaced the stator because the boat would blow the 15A fuse as soon as I put it in. That fixed that problem. I have spark to the plugs but only sometimes it seems. I have trimmed plug wires and had the coil tested. It has a new starter. The boat still will not start. Its going to the dealer Monday unless anybody can come up with something else I could try.
12v test light, the white wire at coil. If it lights, then coil is to blame. If not, then the "igniter" is bad, if all checked out good in the stator area. If problem is starting, AND you have spark, pull the carbs.
150 in both I did take the carbs off today. They were full of crap. Cleaned them up and even got them back together with no parts left over. I have the battery on charge now. Going to give it one more try tomorrow. It it will not start it goes to the dealer
check all the grounds?
