Adding jet pump bearing grease to 2007 GTI SE
aron7575
I am about to attempt to add jet pump bearing grease to my 2007 GTI SE and am unsure as to how much I have to disassemble. I have the information from the shop manual, but do I have to remove the cone or is there a sert to put the grease into and how much do I put in? Any help with this would be great.
No maintenance...
This is a no maintenance item unless you notice grease coming out from around the seal during inspection or in the event you replace the bearing and seal.
If you want to check and fill it, you need to remove the bearing cap. When you take out the 3 small bolts that hold the cone on, tap it gently with a rubber mallet or the palm of your hand. You want to see the seal break in the event there is a little water in the cap. This is important because it will tell you if the seal has been breached.
When your ready to put the cap back on, fill the inside of the cone with your synthetic grease. Make sure your "0" ring seals are in good shape then, put the cone back on.
That simple..................:cheers:
Thanks for the info on the jet pump grease
I only have 22 hours on my ski, should I even be concerned with this right now? I do not want to do anything unnecessary.
Your manual says 100 hours or 1 year for inspection. If you find nothing wrong, then you don't need to worry with it. If you only have a total of 22 hours, then I would not be concerned with it.
