I had my carbs redone with the full kits and the boat was running fine but now I find the idle is rough and I find that it is hard to start. It was done by a shop by guys who had manual in hand.
Once I try to start with one pull of choke, it won't start so I give it gas and so forth and next thing you know it is flooded and I swap plugs with another set and it starts.
One thing from reading the service manual and from visually looking at the carb I notice that it says in the manual to push throttles fully foward and you should see a space between the lever tab and pump plunger of the accelerator pump. When I look at mine, the opposite is true?...I see the plunger being pushed fully in when throttle is pushed all the way forward???
So what gives?
So what gives?
