Acceleration Problem
lbccurrey
I have a 1996 GTS that has always ran very well. Today it started boging down. It idles good and when I accelerate it takes off fine but then immediately bogs down and sometimes dies like the fuel was cut off. It will start right up and run fine but will bog down immediately after I accelerate.
I hope it may be the inline fuel filter, I also read in these forums that there is a filter screen on each carb. Can I just get by with replacing the inline filter so I don't have to take it to the repair shop to tear into the carbs?
I also want to mention another problem that I have had for six years with the same PWC. This is really wild. If I ever filled up my fuel tank past 3/4, it would do the same as mentioned above. As soon as I burned off enough gas to get it below 3/4 tank it would run fine.
At first I thought I was experiencing the same problem, but the fuel is below 1/2 tank and it is still doing it.
Any thought on the current problem and/or old problem.
