Ewhaddix
I bought this boat last winter in Tennessee without test driving it. It had receipts for a new engine and a new wear ring / impeller all within the last 2 years and the boat looked super clean. I got it for a really good price so I didn't feel nervous about the lack of test drive.
Fast forward to this summer. The first time I put it in the water the engine sounded smooth, no hesitation, smooth idle, but it wouldn't accelerate over 15mph and the engine revs to about 4800rpm max. After about 2-3 minutes the engine high temp buzzer comes on. I checked the telltale and it had water coming out but it was scalding hot and I could see steam behind the boat when underway. I let it cool off then idled the boat back to the dock and took it home.
Once home I ran flush water through the cooling system. Water came out clean from the exhaust, the telltale, and the bottom of the jet. I changed the spark plugs. I checked the engine compression and it was 165psi on all cylinders. I checked fuel pressure at idle and it was 35psi (gen 1 motor). I checked for spark on all 6 cylinders. I inspected the impeller and wear ring. No knicks, no scoring. Clearance was checked with feeler gauge and it was in spec and on the tighter side of the tolerance. I installed a temperature gauge on the boat and verified it is indeed overheating. It gets up to 250 degrees if i go over 3000 rpms.
I put the boat back in the water and had 35psi of fuel pressure even at full throttle. I individually pulled plug wires off and each one caused the power to drop off so I believe all 6 cylinders are getting good fuel and spark. The engine still overheats above 3000rpms and the boat will not go over 15mph. RPM's still top off at 4800.
Third time out I replaced the ride plate to hull seal and only had me and my girl on the boat. After 2 minutes it finally planed out and got up to25ish mph at 4800rpm.
Fourth time out with all the kids it only does 10mph and I can't rev over 3000 without overheating. 4800rpms max.
I'm at my wits end. The boat should run great. Air, fuel, and spark are all there and compression is like new. The wear ring and impeller look good. The only thing that looks worn is the stator housing vanes are really chewed up, but I doubt it would cause it to overheat so badly and only go 15mph. Are the stator vanes really that crucial? Any help is greatly appreciated. Thanks.
