challenger1488
I recently replaced my carbs on my 98 challenger 1800 when i went to put them on i had to switch the plate on the end. The one that was on the new carbs was for a single engine sportster. From what i can tell by comparing pics in manuel to what i had. It had a block with a gasket on one side and a plastic like cover sealing the other side with a plate on the end of all that. It also had a extra fuel nipple labeled pulse. I removed all that and put just the plate form my old carb on. It runs now but has some hesitation and wants to bog down around 1/2 to 3/4 throttle. it will come out of it and reach 7000. Just slower then my other motor All adjustments of HSA and LSA are the stock 1.5 and 0 Do i possibly have a jet issue here since this carb was set up for teh single engine boat. Carb was supposed to be set up all stock.
thanks for your help
