a few questions need help !
elpalletero82
:( i jus got me a 1997 speedster and im 100% new to the sea doo thing..i been boating but never with jet boats or skis....well for starters im not even sure which engines i have but i know it has two of them ...lol i have a couple questions.....
1) what is the weedless lever and how does it work ?
2) is my boat suppose to take off quick like a jet ski or take reallllll long ? it feels like something is slipping ? wat can it be?
3) does any one have any good tips or advice on the sea doo thing for new comers like me ?
thanks guys
To really understand how these boats work might solve a lot of your questions. The basic concept of jet boats is jet propulsion. Normal prop boats use an external prop to push the boat along. Jet boats use an internal impeller. Think of it like a big fan blade. It sucks water up through the bottom of the boat and pushes it out the back through a smaller opening, creating force and moving the boat. That is the basic concept. When there is a restriction to the water flow, this thrust is greatly reduced. If there is a leak anywhere on the outlet side of the impeller, you get no thrust. This loss of thrust is called cavitation.
1. The intake on the bottom of the boat can become clogged up with weeds, sticks, and other debris. When this happens, the impeller no longer has water coming through it and therefore you have no thrust to move. The weedless lever is a grate that looks like fingers that covers the intake. When you pull it, it pushes the fingers down, hopefully removing the obstacle blocking water flow. Best way to use it is to stop the boat, put it in reverse. Pull the handle while you go in reverse moving the wheel back and forth. Usually works for me.
2. It should be very fast to get up on a plane. Faster than a lot of other boats. If it feels like something slipping, you may be experiencing cavitation. Could be something as simple as needing a new wear ring. A wear ring is like a gasket the incases the impeller.
3. First step was finding this site. Now you need to read, read, read. When that is done, read some more. The search feature works great.
I am still fairly new to these boats, but this website is a wealth of knowledge. These boats are really basic once you figure them out. Welcome!!!
thanks again for your help...im going to try the weedless lever tomorrow...how hard is it to change a wear ring ? how much does it go for ? and were do i buy it most importantly !?
If you think you have something in the grate and the boat isnt in the water, the lever wont do anything now. You need to just look under the boat and make sure the grates are clear. Look into the back of the pump housing too. You can see the impeller. Just make it is clear from both sides. You can search here for how to change the wear ring. It is a topic that comes up a lot.
oh and if you have a speedseter that is 14.5 ft long and twin engine they are the 717cc mills; Mine usually planes really quick if it bring it to 5000 rpm; then it hopes right up on plane; Have fun with you new boat
thanks guys im going to check and see if anything is stuck under the boat...and try once more if not im going to look in to the wear ring...is it costly????
Wear ring is 40 dollars from most anywhere.. and you can change it yourself.
Go to hoe to on the sea doo section and put wear ring in the search browser, and you'll have it. NO big deal
