Toojay7
Had not seen water in 10 years. Never in salt supposedly. I changed the grey fuel lines and brought it out on the water. Idled it for about 5 minutes and then the overheat warning buzzer went on. Immediately stopped it, brought it back home and inspected the coolant lines. The only issue I found was the head inlet nozzle #10 was clogged with a sand like substance. I cleared it out with a wire brush. When flushing, should I clamp off hose #28 that would send water back out the back of the ski to allow for higher flow through the head to clear it out? Should i check that the head water jacket passages are easy to blow through by mouth or compressor first?
Please let me know your thoughts. Thank you
