Hopefully I'll be able to take the gsx for an extended run this weekend... The only nuisance is that I won't be on a lake, so it will be a different kind of riding. On a good note, I figured out what was wrong with the lanyard... The negative terminal on the battery was very loose, bordering on falling off... An easy fix lol. Here's hoping that the problem is the fuel pump. Thanks everyone for your help. Ill definitely let you know how the run goes.
And I'll stop using seafoam too. As long as I'm running non-ethanol, I'm comfortable not using any additives.
