xc_rider08
i have a a 99 gsx rfi with 62 hours on it. i bought it not running. Was told bad motor (checked compression and its good) but it wasnt a motor issue it was a fuel line pick up tube fall off inside the tank not allowing it to start. I got that fixed and it started right up, but never seemed to run right. Was very hard starting and just didnt pull full rpm, had sluggish top end response and would follow plugs every so often. lots of reading and research led me to check the rotary valve- it was out of spec so i had it machined down and brought back within tolerance. my starting seemed to get better but still wasnt running to performance that i think it should have and still fouled plugs at least once a trip.
Which leads me to my current situation. still trying to figure out why i cant get more then 5700 rpms/ 35 mph out of the turd and why its fouling plugs left and right. i have replaced fuel pump, fuel pressure regulator, and recently the injectors. after replacing injectors it ran great one time for 15 seconds. I started it and let warm up a bit before taking off and it ran like it should, full rpm, 45mph+.. that is until i left off the gas one time and it immediately dropped down one cylinder and fouled the pto plug and damn near left me stranded. swapped injectors around and it followed the injector. replaced that injector with another new one and same thing. didnt matter which spot i put it in when tried to run that plug when pulled would be just dripping wet with fuel. im at a loss now.. two brand new injectors both bad?? What else it could be? Computer?
sorry this is so long, but trying to give as much details as possible cause im stumped on it and very frustrated. would be nice to ride this thing before summer is over.
