Benfica7685
Hello all,
Im having trouble getting my 99 gsx started. I replaced the starter, spark plugs and a new battery Then it was cranking good with power but starting, but then i noticed the starter was almost falling out due to a stripped hole that holds it in place. So i took off the carbs and exhaust manifolds, rotax to get the hole re-threaded. Then put starter back and secured Also changed fresh gaskets while at it. When tried to start It clicked once no cranks to starter then 0 clicks. Relay looked in bad shape so replaced that and changed blown fuses, back to 1 click now. Replaced a bad black cable from under engine block to battery still 1 click. I guess my question is what could it possibly be? I mean i had the power before now its not connecting somewhere, also the starter i Put in was indeed the cheap 35$ one from ebay not the SBT i pulled out .
